My 15 year old son James came home, and he and I then took off the top of the unit -- not the front as I had attempted, we hit the eject button, he saw a small yellow gear had slipped in the way, he then pressed it down to clear the path, and presto we are done! Player works perfectly again.My 15 year old son James came home, and he and I then took off the top of the unit -- not the front as I had attempted, we hit the eject button, he saw a small yellow gear had slipped in the way, he then pressed it down to clear the path, and presto we are done! Player works perfectly again.
You can't post conmments that contain an email address.
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
You could try gently sliding a thin blade in the top of the tray slot to hold the CDs down whilst, equally gently prising the underside of the tray with a small screwdriver (it may help to press teh open/eject button at the same time).
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
my onkyo 6 disc changer was doing the same thing was doing the same thing. i opened it up and noticed the cds weren't quite stopping at the right spot. so i loosened the screw right in the middle of the disc tray. now operates perfectly now. i think maybe with age, the belt tension got a little lighter ant loosening the screw compensated for it.
