The F11 code is caused by either a CCU failure or an MCU failure...here\'s how to tell:
If your machine starts a cycle and the water fills but the drum NEVER turns, your MCU is bad...it\'s most cost effective to buy a refurbished one and you can get them on eBay for $99 all day long.
If your machine makes it most of the way through a cycle but throws an F11 code during the rinse or spin, your CCU has the relay solder / vibration problem...
Most likely you will need a new board. There is a service on ebay that solders for you. If it doesn't work, they will refund the money back to you. These are notorious for failing with the F11 error code.
Check out this guy, he's helped a lot of people.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
