Question about Acer Aspire 5610-4648 Notebook
Toshiba laptop touchpad click not working
From yesterday the toshiba touch pad click is not working. The cursor moves but not able to click it. So please let me know if you have some solution for it.
  • 17 more comments
  • Anonymous Feb 21, 2008
    I have exactly the same problem - please help!!! i accidentaly pressed a shortcut on the keypad and it turned the touch to click off!!
  • Anonymous Feb 27, 2008
    For me too, touchpad click is not working.
  • vdosch May 15, 2008
    The touchpad on my Toshiba has recently started working only until the computer has finished starting up. It then stops working and only the cursor appears and moves, but the buttons on the touchpad don't. What's more, if I plug in a USB mouse, the buttons on the mouse don't work either. It's very strange. Anyone know what the problem is?
  • Anonymous May 24, 2008
    touch pad tap not working..
    anyone plz.. help me
    _mahmud
  • bathwinks206 Jul 08, 2008
    My toshiba laptop touchpad click not working...its stalked...what can i do?
  • atulmanage08 Jul 17, 2008
    my touch pad is not able to finger click though it is moving from last night and my lapi is just a month old,i checkd the settings it says it is ploper..help me out any 1
  • Anonymous Jul 28, 2008
    I am able to tap and move the cursor with my touchpad but not scroll. It used to light up as well and doesn't anymore. When lit, I was able to use the other functions on it. Anyway I can fix this problem?
  • jegi Aug 30, 2008
    Suddenly my thosibha laptop's touch pad click funcationalities stopped working. It would be really great helpful if someone can provide me some solution for this problem.
    Thank you.
  • ellectrastar Oct 04, 2008
    I am also having the same problem, the mouse moves but the double click on the touch pad doesn't. When it's first turned on it works a couple of times but then stops. When I was on the internet the other day the whole thing froze for a while, then started working again but it's only since then that the touch pad has been playing up. It seems to be enabled okay, and assume it must be to work the first couple of times it's turned on. Any ideas as to why it's stopped and how it can be fixed?
  • MellyWirtes Dec 25, 2008
    I can move the cursor, but I can not "double-click"/ select anything with it? Can anyone help?
  • Anonymous Jan 03, 2009
    toshiba touch pad don't work
    i have an acer 4330 and everything on my touch pad works but the scroll...i can't find anything to fix it under the control panel
  • cornbyname Feb 15, 2009
    My Toshiba A135 touchpad no longer works. I bought a logitech mouse ... but it would be nice to have the option. Does fn f9 work? It seems to do nothing on mine!
  • khadracutyo Mar 26, 2009
    i have a thinkpad and i need the cursor, right now i'm using a pc cursor but i want to use the other cursor.if you find the sulotion email me at khadracutyo@gmail.com.
    thank you,
    laptop user
  • Anonymous Apr 11, 2009
    I can move the cursor but the click do not work on the touch pad.
  • Anonymous May 20, 2009
    thanks u have helped me alot my tap did not work and now i dont have 2 go through help support !!!! ya thanks agen
    i used the controll pannel thing !!!
  • rprisheela Nov 24, 2009
    hello.
    Help me out.
    My Left click on the touchpad is not working.  It's a toshiba laptop
    Thanks
  • Derick May 14, 2013
    ok, the touch pad does not work after i put the password when i start my computer... i can only use my computer on safemode
  • DJ VAPOUR
    DJ VAPOUR Jan 20, 2014
    for me too, the left click and the and the touch pad is not working but i control the curser with the touch pad but i cant select with it
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Posted on Jan 31, 2009
  • 7 more comments
  • shantelle_ke Jun 09, 2012
    omg, thankyou so much! this has helped so much!:D
  • mrajpurohit3
    mrajpurohit3 Aug 08, 2012
    thnks a lot..........i solve my problem mahendra rajpurohit
  • satnam_si325
    satnam_si325 Dec 19, 2012
    thank you bhaiya!!
  • ali_maryam
    ali_maryam Jan 09, 2013
    Thanks a lot... it was so0o0 worthful and at the same time so clear
  • maz626nrthfl
    maz626nrthfl Jan 22, 2013
    booooomshackalakaaaaaaa
  • maz626nrthfl
    boooooomshakalakaaaaaaaa
  • bhatti1010
    bhatti1010 Feb 23, 2013
    thank u so much ren434 u have done great jab
    my control panel dont say device setting
  • nazish naheed
    nazish naheed Apr 17, 2014
    it worked for me.. thank u so much..
Right-click on the synaptics pointing device icon in the system tray..it will give you an option that says 'tap to click' select that one
Posted on May 12, 2009
  • Alan STokes
    Alan STokes Apr 23, 2014
    This worked, other solutions didn't. I suppose every version and model is different
My left click stopped working, and all I had to do was hit F9. Thank you!
Posted on Nov 04, 2008
The toshiba Laptop touch pad click is not working. The cursor moves but not able to click it. So please let me know if you have some solution for it.
Posted on Jun 12, 2009
    New Friend:
Hey i have the Toshiba satelite laptop and the touch pad and keyboard has stopped workin completely any help !!! plzzz
Posted on Jun 08, 2010
    New Friend:
I had the same problem with tapping on my Toshiba Satellite, once the tap-to-click function came back, than stopped working again. I found solution myself today. Strangely i could only access the full settings for the touch pad through mouse settings, so the mouse had to be connected. I went to Control panel- Devices and Printers- then Right Click on the "Mouse" icon and clisked on Mouse Settings- then went to Device Settings (with Synaptics Red logo), push the "Settings" button, and then you finally get the full list of settings, including "Tapping", and then you just have to tick the circle "Enable tapping" (mine was unticked, that was the cause of my problem). Hope this helps...
Posted on Feb 18, 2011
  • 2 more comments
  • belldandy Mar 01, 2011
    i tried everything in this site, still my right click is not working...so no copy paste function for me unless i use the mouse..pls help..i trier the control panel mouse device setting, fn f9, enable tapping button, slowing down device speed, updated my device drivers..but still its not working :( it was just fine a few hours ago :( pls help..
  • Kim-Johnny Moland
    Kim-Johnny Moland Sep 25, 2012
    I just have to thank you so much for being able to detect this magick trick; I no longer loose focus everytime I click...
  • Maria Selvi M Jul 15, 2013
    I tried this one genious My problem also solved Thank you so much..
  • Jeff Jinx
    Jeff Jinx Feb 08, 2014
    Thank you SO much!
The tap is on but it still does not work
Posted on Jul 14, 2008
  • 39 Answers
Hello:
The first place I would check is under Mouse in your control panel. You can turn on/off the tap tap on your pad there.
If that does not resolve the issue let me know...more tricks up my sleeve.
Best of luck my friend.
SeekPCRepair
Posted on Feb 09, 2008
    New Friend:
Hello dear friend! i have a problem regarding to touchpad. it cannot be tap even settings for the touchpad is on..my laptop model is SATELLITE L655 TOSHIBA..i already checked some post solution on this website but i cant fix it..In this model there is any settings for mouse TAPPING..
hope you can help me for this problem because i cant use my laptop conveniently.
Posted on Mar 14, 2011
    New Friend:
I have the Toshiba Satellite P505 and i can't tap on my mouse pad.. please help me out
Posted on Mar 25, 2010
    New Friend:
I have Toshiba Satellite L650-1KU. I was playing mahjong and it suddenly only moved, and only the right click works. I don't know what do do. F9 doesn't work and tap is enabled. Help?
Posted on Oct 07, 2012
    New Friend:
I have the Toshiba Satellite c660-1tk and i can't tap on my mouse pad.. please help me
Posted on Apr 03, 2012
    New Friend:
Thanks so much . i can fix it. it's excellent. thanks again.
Posted on Apr 01, 2010
    New Friend:
Check speed on mouse in control panel. I slowed mine down a little and now it works
Posted on Feb 04, 2010
    New Friend:
My pad stopped working after only a few days.... lights off, nothing works... its enabled and everything... but just gone... drivers good... but hardware not detected in device manager....
Posted on Mar 28, 2010
Here is a little something if you are having trouble with the "tap to click" with the mouse touch pad.
Control Panel...Mouse...Device Settings tab...
in the Device settings tab...make sure there the device is enable...then, there is a settings box. In there..click on it, go to "Tapping"...check the Enable checkbox. That will turn on the "tap to click" function.
Posted on Oct 21, 2008
  • 12 more comments
  • l_pantha Aug 18, 2010
    awesome!!! thank u, it really works.
  • atexas1946 Dec 11, 2010
    I had same problem, the toshiba touch pad tap click is not working. The cursor moves but not able to click it. Plugged in regular mouse and it worked fine. Followed above instructions about going to control panel, mouse, and checking to to see if tapping was on. After further checking I found that the left button on the touch pad was shut down and would not move. Using a needle along the side of the button I GENTLY pulled upward and it popped loose. Unplugged mouse and Pad is working great LAnderson
  • thisisjas Jan 08, 2011
    Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!! simple solution worked for me also.Now wondering what happened at first place .........in anycase thanks again.
  • alsdfhjlh Feb 20, 2011
    thank you so much i really appreciate it
  • vafa_rustam Mar 19, 2011
    i had such problem from yesterday and didn't know how to resolve. THANK YOU VERY MUCH. it really works.
    I had this problem from yesterday and couldn't resolve it. THANK YOU VERY MUCH. it really works
  • priyoheart May 15, 2011
    Thanks dear.. it really help me a looot........
  • rsim263029 Jul 15, 2011
    Thank You, Thank You!...This did the trick!
  • Dama Oct 19, 2011
    Thanks a lot.
  • Izzy Nov 01, 2011
    Thank you so much! I did all these steps and it worked! thanks a million!
  • shadae blancaneaux Nov 27, 2011
    Ok but how do i get to the device settings if the clicker doesnt even work!
  • Senior Dec 04, 2011
    thanks, ive been trying to figure this out for a very long time
  • shabbir_ksa2
    shabbir_ksa2 Feb 05, 2012
    Thanks, a little knowledge has solved my problem, now my touchpad is clicking by following the solution (18)
  • Cheryl Gruwell Mar 04, 2013
    My touch pad works but the left button below the touch pad is not working properly. At first it would not work at all but now it acts like the back arrow on a web page. Any ideas? I prefer the buttons to tapping on the touch pad.
Unless the touchpad is disabled, my cursor arrow roams and re-directs the instructions from the keyboard. Any ideas?
Posted on Dec 17, 2008
    New Friend:
I went into devices, and changed my left click button to my right. it works now. gives me a bit moe time for
Posted on Mar 08, 2014
    New Friend:
Thanks for the advice to go to device settings and select tapping option...worked perfectly!
Posted on Jun 19, 2012
It sounds as the 'click' is faulty. it may need replacing. If you have food or anything has found its way under the 'click' it may either be stopping it from returning to its positions OR the 'Click' as you put it is actually faulty.
Posted on Nov 18, 2015
Press fn and f9 and you can lock and unlock the tuch pad
Posted on Oct 26, 2008
  • rooskipow Jan 29, 2011
    Fn and F9 worked just like you said. I don't know what I did but that undid it. Thanks a lot.
  • LalPatola Feb 18, 2011
    I never knew that . thank you!
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: my toshiba laptop cursor doesnot move when i touch
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Posted on Sep 08, 2009
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Posted on Oct 31, 2008
Anonymous
SOURCE: touch pad not working correctly
If u are having Synaptics Driver....then
check that Tapping is enabled...
follow steps to know that:
Open Control Panel..
Now Open Mouse
Now click on tab "Device Settings"
then Click on "Settings"
a new window popups
Click on "Tapping" which is listed on the corner of the window
Now after clicking on it...on the right...check that there is "Tapping Enabled or not"
if not...click on that White box...
and Apply
then ok
Done :)
_________________________________________________________________________________
Sorry 4 my english!
Posted on May 17, 2009
My laptop cursor stopped working/moving since yesterday even when i touch the touchpad of the laptop, pls help!
Connect an external USB mouse.
Click Start
Click Control Panel
Click Mouse, and change the settings to ENABLE the touchpad (you must have DISABLED it).
Mar 15, 2011 | Computers & Internet
I have some how deactivated my touch pad
power cucle your computer make sure that you turn off ther computer completely.
if still the same then you need to uninstall the youchpad driver under uninstall program. look for the Synaptics TouchPad Driver.
I check the model of your computer under the toshiba wesite and I found out that you have a synatipcs driver.
Then go to this link to download the driver
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2175704&rpn=PSLB0U&modelFilter=L300-ST2501&selCategory=3&selFamily=1073768663
Note:
The touchpad still works even without the synaptics driver. Once you uninstall the touchpad driver and still yur having the same issue then it is a posible touchpad issue means the hardware itself.
Mar 28, 2010 | Toshiba Satellite Pro L300 Notebook
When typing an email the keys skip back to the
When I have seen this happen, the touch pad was set overly sensitive. When you are typing, your palm may be moving the cursor. If this happens at other times, then this can be corrected in the control panel. Go there and click on touch pad. It will have settings to set the sensitivity for the mouse pad, speed, double click/single, etc. You can change the settings to be more suited to your hands.
FYI: Older laptops were more susceptible to touchpad errors and I have even seen the area on either side of the touchpad to cause the mouse cursor to move and jump.
Good Luck
Dec 16, 2009 | Toshiba Computers & Internet
The mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Aug 20, 2009 | Toshiba Satellite A135-S4527 Notebook
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
Jul 30, 2009 | Compaq Presario CQ60-204NR Notebook
Cursor moves, wont click!!
i think there may be two reason.1/some setting may be worang-go on conttrol panel and chose printer and other hardwere. inside click mouse and look setting.2/ your touchpad driver may not be working properly. stall it next.
Jun 11, 2009 | Toshiba Satellite A105 Notebook
Right & left click buttons not working
hmm quite interesting
has your laptop suffered some damage
i recomend you try to disassemble your laptop and check the connector for the touchpad.
dont know how try this site:http://repair4laptop.org/disassembly_acer.html
Nov 30, 2008 | Toshiba Satellite A105 Notebook
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
Touch pad possessed.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
Acer Aspire 5610-4648 Notebook Logo
77,301 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
