Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
image Regulator may difference on all set ups good luck you may have a Regulator on Air-Compressor Mount on the Gauge or next to it this allow you to set a pressures from 0 - 200 psi this to helps you maintain steady and reliable operation of your air tools.
Yeah if no visible leaks your compressor rings are worn an will need to be rebuilt. Check around for rebuild kit and maint cost. May be just as cheak to buy another one, you can get deals on ebay and craig's list. Good luck..Google the model# you may find parts..
you can see it here:http://topportableaircompressorreviews.c...
