My wii would was dropped. The wii would make the noise of trying to eject the disk but it would not. I had to disassemble my wii. Several videos are on youtube. You will need a special wii screwdriver (I used a t4 driver from Home Depot to get the special wii screws out). A gear at the top of the cd reader popped out of place. (The gear is small white worm style on a small silver metal shaft that is an inch or two long). I pushed the gear back down ito snap it back into place. All was well agaiin. A videio on youtube also suggested a black drive band that may have slipped off its track. This black band drives the gear that connects to the worm gear. Hope this helps someone.
Hmmm send it to nintendo maybe it will work
It's the ejectijon button cause i have the same problem but with a wii disc
Hi Guys & Gals,
It is actually very easy.
1. Switch off your Wii consule
2. Pull out the power cable
3. Reconnect the power cable
4. Switch Wii consule on and quickly press eject.
This should do the trick
Cheers
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right
if it is stuck and not coming out then the top bendy bit of the eject
button put your nail through it and press it down it should eject but
after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Really its just the eject button!! Ohh wow thats great how can I fix it??
same problem here, none of this is working either.
