I see one definite issue here, and possibly a second...
First, the TVI isn't controlled by a 0-10V dimmer, it needs to be controlled by a line-voltage dimmer (usually one that's rated for fluorescent dimming ballasts). The point of the TVI is to convert a line-voltage dimming signal into a 0-10V dimming signal. If you already have the 0-10V dimmer, you shouldn't need the TVI.
Your potential issue may also have to do with LED/dimmer compatibility. In some systems the light fixture sources the current, in other ones, the dimmer does - and the wrong combination can causes errors. Regardless, I suggest getting the make
You must have an led dimming controller also wired to grxtvi 0-10v
