Question about Nintendo DSi Black Console
Re nintendo wi fi usb connector. Received message
Re nintendo wi fi usb connector. Received message on pc when installing to say if I have firewall or virus protection it may affect the installation. Continued to install. When tried to connect to internet from the nintendo dsi console could not connect and received error code 051103. I don't want to remove my firewall or virus protection so not sure what do do now. Would appreciate your advice. Many thanks.
  • 644 Answers
Try port fowarding, make an exeption rule on the port that you want to connnect with in your firewall
Posted on Jan 15, 2010
SOURCE:
What does error code:51099 mean
Error Code: 51099
The only access point within range of your Nintendo DS is not configured or is not compatible with the Nintendo Wi-Fi Connection (such as those found in many Hotspots).
Where are you trying to connect from?
1. Wireless Home Router (please scroll down)
2. Nintendo Wi-Fi USB Connector (click here)
3. Hotspot (click here)
Using a router:
1. Please make sure that your router is not on our list of incompatible routers. Click here to view the list and locate your router (if available). If it is listed as "not compatible," then it appears your router will not work with the Nintendo Wi-Fi Connection. Consult the compatibility chart for recommended routers, or consider purchasing a Nintendo Wi-Fi USB Connector. If your router is not listed as being incompatible, please proceed to step #2.
2. Ensure your router has the latest firmware installed. Visit your router manufacturer's website and look for any updated firmware that may be available (these are typically found under "downloads" or by searching for your particular model number). Contact your router manufacturer for additional assistance.
3. Make sure that your network's name (SSID) matches exactly to what you have entered in the Nintendo DS.
1. Log in to your router using the default IP (consult the router?s owner?s manual for assistance).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the Nintendo Wi-Fi Connection Settings of your Nintendo DS that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
4. Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router Configuration page.
2. Use the drop-down box on the left to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing such things as the Transmission Rate.
5. Your router may not be assigning an IP address to the Nintendo DS. Try manually assigning an IP address to your Nintendo DS.
1. The first thing you'll need to do is find out what IP address your router is using. To do this:
1. Click the "Start" button in the lower left-hand corner of your computer.
2. Click "Run."
3. Type "cmd" into the box and press Enter.
4. Type "IPCONFIG/ALL" and press Enter. The IP address displayed of the PC will be displayed.
The IP address you going to assign to the Nintendo DS must be 10 digits higher than the PC?s. (e.g., 192.168.1.100 becomes 192.168.1.110)
2. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this, please click here.
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Using a Nintendo Wi-Fi USB Connector:
* Does the Blue Wi-Fi registration tool icon appear in the system tray of your PC (typically this is found in the bottom right-hand corner of your computer screen, near the clock)?
1. Yes. If the connector has been inserted very recently, it may take several moments for it to establish a connection. Retry.
2. Yes. If the USB Connector is inserted directly into the PC, trying attaching the plastic extension cable that came with your USB Connector. Getting some distance between the PC and the USB Connector may help the signal strength.
3. No. Is the software installed? Is the USB connector inserted? Restart the PC, and if it still does not appear, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
4. Yes, but it's gray. Is the USB connector inserted? Right-click the registration tool icon and choose to run the registration tool. If it does not respond, restart the PC. If it still does not respond, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
Oct 24, 2010 | Computers & Internet
Wii system update code error 32007
Error Code: 32007 There was a problem downloading the latest Wii update.
Please check the following:
  1. Our servers may be down temporarily or experiencing a high amount of network traffic, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  2. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  2. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  4. If you are still receiving this error code, please click here for assistance.
  1. Does your PC have any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.) installed? If you are using the Nintendo Wi-Fi USB Connector, and have a software firewall or other computer security program installed on your computer, there may be additional steps you must complete to allow a successful connection.
      "Trusted" Applications:
      If your firewall or PC security program keeps a list of trusted applications (also known as a "trusted zone"), the following programs are installed with the Nintendo Wi-Fi USB Connector, and require internet communications. If prompted by your firewall or PC security program, add these to the list of trusted applications. This information may also apply to certain computer security applications, such as anti-virus, anti-spyware, etc.:
      • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
      • Setup.exe (when installing the USB Connector)
      • SoftAPInstDrv.bin
      • mdriver.exe
  2. If you are using a router, you may need to temporarily disable the router's firewall to allow the Wii console to connect online and receive a system update. Once the update is received, you can turn the firewall back on. For information on locating and disabling your router's firewall, please consult the router's manual or contact the manufacturer of the router.
Jul 28, 2010 | Nintendo Wii Console
Error code 32007
    Wireless Router:
      • SoftAPInstDrv.bin
      • mdriver.exe
May 22, 2010 | Nintendo Wii Console
Error code 32004
Error Code: 32004 Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  5. If you are still receiving this error code, please click here for assistance.
      • SoftAPInstDrv.bin
      • mdriver.exe
  3. If you are still receiving this error code, please click here for assistance.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
May 15, 2010 | Nintendo Wii Console
Am hooking up our Wii to our wireless inter-net, got an error code of 32oo7? Was up.
From Nintendo.com:
Error Code: 32007
  1. Our servers may be experiencing a high amount of traffic with a particul update, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  3. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  4. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
    Wireless Router:
      • SoftAPInstDrv.bin
      • mdriver.exe
    • "Trusted" Applications:
  3. If you are still receiving this error code, please click here for more assistance from Nintendo.
Nov 20, 2009 | Nintendo Wii Console
Im using Wi-Fi USB connector for internet connetion, but it keep show up error code 52140, not able to connet... even my USB connetor is showing the running man mark on my computer?
Try this..
1. On the computer with the USB connector, get a command line (start -> run -> cmd) and type the command ipconfig /all
2. Normally it will show multiple DNS addresses.
3. Now connect your Nintendo USB connector.
4. Go to your network connections (usually under control panel) and right click the USB devices.
5. Under the general tab, look for Internet TCP/IP, highlight it and click properties.
6. Click Use the following DNS Addresses and enter the two addresses from step#2.
Nov 02, 2009 | Nintendo Wii Console
Wii wireless connction has error code 51040
rror Code: 51040 Please try the following troubleshooting for the Nintendo Wi-Fi USB Connector
  1. Verify that the Nintendo Wi-Fi USB Connector is installed correctly and that the PC is turned on (the USB Connector will not work while the PC is turned off).
  2. Try our interference troubleshooting steps.
  3. Are you using any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.)? If so, you may need to add the Nintendo USB Registration Tool software to a list of "allowed" programs or "exceptions." If this is unavailable, you may need to disable yousecurity program before the Nintendo Wi-Fi USB Connector can access our servers. See Nintendo Wi-Fi USB Connector "Firewall troubleshooting" for more information.
  4. Try uninstalling the Nintendo Wi-FI USB Connector software, and installing the newest version. To get uninstalling instructions and the latest version of the software, please click here.
Nov 29, 2008 | Nintendo Wii Console
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
Nintendo DSi Black Console Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
