GE 25942GE2 Cordless Phone System Logo
Posted on Jan 14, 2010
I need to set it up
I need to set up for the answering machine date, time minutes and hour and number of rings before it answers
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
108
Points
Which dongle to write imei A28 for aldor mobile
How do I set the number of times phone ring before the machine take the message?
Press and hold the SET button to enter the change mode. After the time and date you can change the rings to answer.
Full details are in the "Changing the Settings" section of the manual (page 9). If you need the manual, you can download it at
http://www.home-electronics.net/ge/pc/IB/29869GE2_IB.pdf
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
2answers
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
How do I change the Time?
To set the Time
1 Push the "Select" button on phone base. The phone will enter in setting mode.
2 Use up and down arrows to choose between "12h,and "24h," for 24-hour display. Press the "Enter" button when done.
3 Selet the hours value using the up or down arrow buttons and press "Enter."
4 Select the minutes still using up or down arrow buttons and press "Enter"
5 Choose "AM" or "PM" Using the up or down arrow and press "Enter."
To set the Date
1Enter in date setting mode by pressing the "Select" button twice.
2 Change the year using the up or down arrow button, then press "Enter."
3 Set the month using the up or down arrow button then press "Enter."
4 Use up or down arrow buttons to select date and press "Enter" to finish.
To extend the number of rings (selected models only):
1 Press the answer button on the base (answer off), this will give you up to 15 rings before the answering machine turns on and takes the message.
2answers
I do not know how to change the time and date on my Uniden phone, nor length the times it rings before the answer machine goes on.
To set the Time
To set the Date
Machine will not answer to take a message
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/28112EE2_IB.pdf
1helpful
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
14helpful
Bellsouth model 1188 digital ans machine
Press and hold the "clock" button. You will hear a beep and the display will begin flashing a number which represents the day of the week. 1=sun, 2=mon, and so on. Press the left and right arrow buttons to scroll through. After choosing the day, press the "clock" button again to set the hour. It will start with 12 am and go through 11pm. Press "clock" again after setting the hour to set the minute.You will be able to scroll through 0-59 to choose the minute. When finished, press the "clock" button again to exit the time setting feature.
28helpful
HOW DO i SET TIME ON A 43-3829 ANS MACHINE???
One thing Radio Shack's answering machine [model number 43-3829], is NOT, is intuitive. But I guess you know that already. ;-)
To set the date and time, perform each of the steps below in quick succession, otherwise the machine will drop you out of the process and you’ll have to start over. You have about five seconds between each step, so try and make a mad dash for the finish line (Steps 4.-5.).
Setting Date and Time on Your Answering Machine:
(To set Day…)
1. Turn the answering machine on and hold down the TIME SET/CHECK/>> button until it beeps twice.
2. Press ANNC/DAY/<< repeatedly until the correct day displays / is indicated.
(To set Hour…)
3. Press REC repeatedly until you reach/hear the correct hour.
(To set Minutes…)
4. Press >|| (PLAY) repeatedly until you hear the correct minute(s).
(To Review/Confirm...)
5. Press TIME SET/CHECK/>> once. The machine will play the time and day you entered.
Note:
To exit/cancel the time- and date-setting mode, press ON/OFF/STOP once.
Hope this helps! If you have additional questions, please let me know and I’ll do my best to help.
Gail
2helpful
3answers
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
