Cd show been loading and spins when you hit play but just spin and no play, on the display shows the # you want to play but does not moves to next track just stays for ever on same track and do not displays minutes playing either. and the worse is no sound
The laser lens needs cleaned most likely, you can purchace a cleaning disk, or take the unit apart and used a eyeglasses cloth and very gently wipe the lens clean. the lens will be very small and near the motor that spins the cd. when wiping it off, wipe in one direction only. if that doesnt work then the laser has become weak or has quit working
it plays a cd for about 3 minutes or so. maybe one or 2 cuts and then go to sleep again. the disc keep spining and the screen shows the nbr of the cut been played without showing the minutes into the song. it will continue doing this until I just stop it. Any more suggestions??? help!
