I own two of these strollers- but can't remember what side! haha.. anyways- I think the 'locking mechanisim" is on the right side. On mine- it's a big red "clip".. when the stroller is closed it will be located between two of the metal posts--- when you find it- all you need to do is press down on the side with the grooves- and it will spring the other side up off the clip and as you are holding it- you should be able to open the stroller enough that you can just grab the hand rails and pull it open and everything will 'snap' into place and you're off! Good luck!
