There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Hello Bruce Hubley, thanks for your post!
Based off the information you have provided your Frigidaire wall oven will not heat up higher than 400 degrees. It may be a problem with your thermostat or control panel. I would recommend performing a reset on your oven and you can do that by disconnecting power from your oven for roughly ten minutes. If this does not help correct your issue I would suggest having a professional come out to provide the proper repairs on your oven. Best of luck! -Matt
