That or a heater coil high limit switch has blown. The high limit switch is a safety device that prevents the dryer from getting too hot and catching fire. I would check the belt and motor first bt removing the back and checking the belt and motor by hand turning the dryer drum and observing the belt and motor. If the motor is bad or going bad you should see signs of slight charring at the air vent holes onm the motor and you will for sure smell it. Good luck
Dave
