You may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
