I have the above reverse cycle airconditioner but i cannot get the heating to work. When i switch on the remote, the units Operation Indicator light and Timer Indicator light flash simultaneously. I think it has something to do with the Test Run button being pushed but the manual does not say how to fix this, apart from saying to press the Start/Stop button. Obviously I've done that and it is not the answer. Can anyone help? :)
Try to reset the unit by unplugging the power supply or off the circuit breaker for 10 sec. the "on" again and operate the unit. But if it wont work You need a qualified technician to correct the problem.
I have the temperature gauge set to 24 to heat and only cold air is coming out. Help?
no heat , operation light flashes five times in intervals and the timer light flashes continuously model number AST24LBAJ
I have the same problem, the airconditioner works fine but when i switch it to the heater - no air comes out. the operation light keeps flashing. the out outside outlet makes a noise as if it is working but no hot air is coming out. HELP!
i have the same problem and the solutions dont work pls help me
I Have the same Problem Works well on Cooling But heat no good!
I have similar issues only the fan is working but cooling and heating is not anyone got any ideas why
