Fossil Philippe Starck PH1034 Wrist Watch Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant set the time, I would like to set the correct time, know how to set the alarm and be able to view the day date and time, I think it can show all of that....It was working and now, nothing :(
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 13, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290884
Points
7081
Perhaps you have operated a number of options that have confused the poor thing! I suggest that you obtain a copy of the user instructions and to do this you should go to the Fossil web site (fossil.com) and enter "Phillipe Stark" in the search box.
Got to the bottom of the screen and there is a menu of alternatives; choose "customer care".
The next page has a menu on the left, choose "watch instructions"
Select the illustration that matches your watch and choose the instructions by the model number.
If you cannot get the watch to operate satisfactorily even when you have followed the instructions, then you can only contact the manufacturer and aask for help.
I do not know how to set my granddaughter's watch, and she thinks I can do anything....
Hi rizzomargare,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
How do you set the time qnd day and set the alarms
Hi nkjensen,
You can change the time of your Timex watch by following the steps below.
Hope it helps.
How to set time and date
Hi janssen4,
You can change the time and day of your Timex watch by following the steps below.
Hope it helps.
Hi aremoresun,
You can set the time and date your Timex watch by following the steps below.
Hope it helps.
I bought my son a watch for Christmas and there were no instructions that came with it and for the life of me I cant figure out how to set the watch of the time and date.PLEASE HELP thank you Deb
Hi dibbles624,
Hope it helps.
I do not know how to set the alarm
Hi benchilcott,
Hope it helps.
Can't set the date and time
Hi sgarraux,
Hope it helps.
I have A 1440 sports watch. I cant get the chime or alarm to sound off.
Hi Guest,
Hope it helps.
19helpful
2answers
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
7helpful
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
