Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Logo
Anonymous Posted on Jan 13, 2010
Caller ID problem with KX-FHD332
Hi there. I have a KX-FHD332 for several years. But about a year ago, the phone stopped showing me the caller id's. Instead it shows first my own number, followed by the first numbers of the caller id. My phone company says the problem is in the hone. when I contact another phone, the caller id works great. But the KX-FHD332 again shows my own number in the beginning. What do you think, can the problem be solved? Thanks in advance!
  • Anonymous Jan 14, 2010
    Hi there - thank you for the fast answer. Howeer - the problem is not when I receive faxes, but when i receive phone calls :) They all appear starting with my own phone number. Maybe some combination of buttons is required... or somewhere in the menu... Thanks in advance!
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Jan 14, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1007072
Points
9738
Your fax machine does not actually have CALLER ID, it reads what the sending fax machine has programmed into it. If it was never entered in, you won't see it.
Caller id problem in mypanasonic kx t7730 telephone ?
you pay your phone service provider to have caller id
Caller id stopped working
Dial *31# followed by the phone no and send and see if it would show the id, if it shows i will tell you the next step
3helpful
I HAVE A PANASONIC KX-TGA402 CALLER ID NOT WORKING
I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
External caller ID does not display on either line talkswitch 284
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Hi, I have a Panasonic KX-T7636 and I dont see any caller ID on incoming calls. How do I fix this?
Okay well i'll just give you the long and short. If your caller id was working and then it all of the sudden stopped working you need to call your phone service provider and notify them. If you just got these phones installed then you would need to get a caller id card and turn on the caller id prompt from your phone system.
3helpful
Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
1helpful
Caller ID indicator
Caller ID indicator is probably a new call notification. You should be able to review the incoming calls list even if you do not have caller ID to stop the light from flashing.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
