Unable to init.
Error message
Unable to Change
Unable to Clean
Unable to Init
Unable to Print
Unable to Scan
Cause
The MFC has a mechanical problem.
?OR?
A foreign obstacle, such as a clip or ripped paper, is in the MFC.
Solution
Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it.
Check whether the MFC has faxes in the memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it.
?OR?
If faxes are present, you can transfer them to another fax machine. Go to Step 3.
?OR?
You can forward the faxes to your PC. Please see Transfer faxes to your PC.
Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it.
You can transfer the Fax Journal report to another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1
You can move the faxes from your MFC?s memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC.
3. To transfer all faxes to your PC, press 1.
?OR?
To keep all faxes in the MFC?s memory, press 2.
4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it.
(For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
