The RAZRs wont add a signature, even if u put one in. i have the same problem on mine. Ill c wat I can do, but idk if i can get it 2 work. A nice fone 2 get wud b a samsung, THANKS 4 RATING
On some phones it has it on other it doesn't. i use to have the same problem until i changed my phone and i went to templates and at the bottom it said signature
U ppl arent 2 smart. on any model of razr u cant put a sig in. razr is a nice phone but face it u just cant have a sig. period
You have to put in a signature and then after u type the message, go to ur options go to insert and insert singnature...its way at the bottom...
♥[[BRiTT]]♥
For the Motorola RAZR V3XX, here is what to do: Go to menu, then messaging, then click the options button, Scroll down to Setup and select Message Setup. Then you will see the Signature line at the bottom, scroll down and hit change. Then type in your signature.
I have a regular razr for att wat do i do? I WANT A SIGNATURE!!!
Help! IDK WHAT TO DO
email [email protected]
Razors ****
I have the same problem. i have a razr2 and i have at&t and i can't figure out how to put my sig in. i have tried what u guys said none of it works! its soooo annoying!
Hey I have a SOLUTION all of you guys are all wrong the only way you can have a signature on any motorola phone is if you select add signature after every message you create i used to work for tmobile and now i work for AT&T and I have a V3xx
I used to have the reg. razor then i got the v3xx. the reg razor does it automatically but the v3xx doesn't. and to : axgrinder32 ur the dumb one bec. the reg one does do it. u can still hav a sig. it just doesnt do it automatically.
That is not a option for TYext Bro..just multie media
1.go to messages
2.go to quick notes
3.click new quick note
4.type in wut u want
5.type a text message
6.click insert
7.click insert quick note and pick your quick note
Will someone plz help help me i have a regular razr and i dont know how to make it automatically make it insert my signature when writing a message
email me at [email protected] if u know how thanks,
Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
i'm tired of having to manually insert my signature, is there another way to do it, automatically?
I have to put my signature in my phone every time i send a text message and im getting tired of it.
I cannot place a signature without manually inserting it >.<
i cant put a signature at all after my text messages. i have t-mobile help
I need to know how to get the signiture after the text and find where to put it at!
NEED TO KNOW HOW TO SET A SIGNATURE FOR MY TEXT MESSAGES, SO THAT IT IS INCLUDED AT THE END OF THE MESSAGE AUTOMATICALLY.
i go to my txt messages on my razr phone and put a signature but it only comes up when i send a picture
!~! i love my family!~!
!~! i love my family !~!
!~$money in the bank$~!
I want a signature at the end of my text messages. I see where to put what I want for my signature but the only way I know how to put a signature on my text messages is to insert it every time I send a text message. Is there a way to have my signature to automatically be put in my text messages on its on?
i am trying to put a signature but every time i search im not getting what im looking for i already tried the auto signature but that did not help becasue it only did it for pictures
I have the original RAZR phone but I am borrowing it from a friend, while I was using it I figured out how to put a signature in but I am now giving it back and don't remember how I did that to go back and erase it.
eff. i have the same problem!
all that i know is my phone is a razor im not sure which one. but when i change my signiture it never shows up
this
i wnt to put my sig. at the bottom of my texts but i dont know how to make it do it atomaticly but i know ther is a easir way then typing it evrey time
same hurr
i know like how to insert it but you have to do it manually EVERY time
it blows
i dont know how to get my signature to automatically insert intself, so i dont have to insert it everytime.
how do i get to the message setup to put a signeture under the text?
my phone does the same thing i wish it would do it automatically
i have the exact same problem
