If you mean the electric transfer case shift moter put somone in the
truck get it up on a lift(if you have access to one) start it up put in
4wd see if output shaft from trans. case to frt. diffirential if shaft turns
check the hubs if i remember correctly gm had problems with those
hubs in 95-96
ps if you can't use a lift, level paved ground+ 4 STURDY jack stands
hope this helps any other ? lemme know good luck
