La Crosse Projection Alarm Clock with Temperature and Humidity Display Logo
Posted on Jan 13, 2010
What does LL mean on the humidity display? - La Crosse Projection Alarm Clock with Temperature and Humidity Display
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3380
Points
Low temperature/low humidity (LL)
Ivaylo Terziyski
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 07, 2015
Ivaylo Terziyski
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3422
Points
8
Humidity is under 20%.
The humidity sensor reads "LL" ... What does that mean for a gro1 digital weather station ?
Humidity value is lower then the forecaster registers , they normally go no lower then 20% . If you are getting an LL that could mean where you are located the humidity was lower then 20%
Humidity display window always LO
I would go to a box store and get a guage that displays relative humidity and see where it settels at. Your humid may actually be low.
1helpful
2helpful
What do the control knob numbers mean. Does the lower the number mean less humidity?
If you have an analog unit the humidity extraction knob should be turned to Maximum.
If you have an LED screen, the arrow down button is what determines the amount of humidity to be removed and maintained. In this case, the lower the number does mean less humidity.
On an analog unit, it's the higher numbers that determine the lower humidity levels.
I hope this helps you and thanks for choosing FixYa.
2helpful
2answers
What does bucket full mean on my frigidaire portable air conditioner mean
this type of unit has a condensate drain bucket that holds the condensation that is removed from the air, this bucket needs to emptied when the light comes on.
Is this a low temp model, as it is not dehimidifiying but fan is running
The model you have was made by Fedders for Maytag. The fan runs as a recirculating fan, to continually sense when the humidity level rises, above what have the unit set on. Here in, may be the problem. If you have the humidity level set higher than 50%, that's pretty high and the unit want remove much if anything. It will just continue to maintain that level. Keep in mind, the unit's humidity level must be set LOW, for the compressor to kick on and start removing humidity. By low, I mean 35% or minimum, if your unit does not have an LCD display.
I must caution you, that there is associate on this website that would tell you, that the level should be set on Maximum. Believe me, that simply is not the case. That is, unless you want your home to be hot and humid.
Hope this helps you to troubleshoot and solve the problem.
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
2helpful
2answers
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Intermittant failure LED display of my TEAC SR-L50 Clock Radio
Offhand, the failure of the 2 segments would seem to be intermittent (granted affected by humidity). Technically, I would suspect a case of cold solder. They could be replaced or if you know somebody who could solder, then it is a matter of re-heating the joints and adding a dab of soldering lead.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Maytag MMV5165BA - E-63 on display
Sounds like a problem with a temperature sensor or humidity sensor.
Top La Crosse Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
