Maytag washer fills up normal, but does not start the wash cycle. It hums and the element heats up, but the water does not get pumped/sprayed inside. It does however, drain fine. I have dismantled the interior and found no clogs - everything is perfect. When checking underneath, there is only the one water line feeding the side of the dishwasher - no other water lines attach anywhere else. I suspect the motor is bad and I noticed droplets of water coming from around the motor underneath. That tells me the o-ring inside is bad. I assume this thing needs turned upside down to remove the motor and o-ring to replace?
Maytag washer fills up normal, but does not start the wash cycle. It hums and the element heats up, after a few min the thing shuts off , the lights turn off and nothing happens. it does however, drain fine. , there is only the one water line feeding the side of the dishwasher - no other water lines attach anywhere else
I have the same problem
