Follow the instructions on p.12 of the following pdf:
http://www.geberit.com.au/web/appl/au/wcmsau.nsf/files/usr-pdf-Geberit_Outlet%20Valves.pdf/$file/Geberit_Outlet%20Valves.pdf
Basically, push down the 'full-flush' (big) side of the flush button and look at the side of the remaining (small) side of the button. There is a little slot that allows you to pull the small button out. You can then pull out the big side of the button which exposes a screw that allows you to pull the lid off.
Hope that helps.
thankyou very much
Thanks so much
Thank you!!
Excellent, thanks - glad you had something in the description because the link no longer exists, but your description was nenough to help me. Cheers
