Question about Watches
How do you calibrate the compass for a Lacross XG-55 wrist watch
  • 343 Answers
Here is the manual for your watch. It tells you how to calibrate the compass. Print out the manual and keep for future reference.
http://www.lacrossetechnology.com/xg55/manual.pdf
Good luck. Did this help you?
Posted on Jan 12, 2010
SOURCE:
Is watch dead or is battery dead
If your numbers dim when you push any button, it's probably a battery. If your numbers are off or very faint same problem, battery. Those watches take a 1.50 V cell because of the light, and multi functions. Any decent jewelry store should be able to have you in and out in 10 minutes or sooner.
Good luck, gabe.
Oct 22, 2015 | La Crosse XG-55 Wrist Watch
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Lacrosse xg 55 - Do I need to replace the battery? When I use the light nothing displays is this a battery issue? How do I change it if it is the problem?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for
the small cost saving in doing it yourself.
Jul 16, 2010 | La Crosse XG-55 Wrist Watch
Changed battery now it won't come on
Try shorting the battery case to the watch chassis (using a pair of tweezers perhaps).
This seems to be a standard instruction and I think this resets the watch.
Apr 24, 2010 | La Crosse XG-55 Wrist Watch
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
I lost my owner's manual for my Casio SGW-100B. When I try to use the compass it asks me to please calibrate
Above link no longer valid. Here's the current one:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3157.pdf
Also, the key was inputting the correct #, in this case 3157 - NOT the 100B - at the following page:
http://world.casio.com/wat/download/en/manual/
I had almost given up when I looked again at the back of my watch and found the other number.
Sep 16, 2009 | Casio SGW100B-3V Watch
Setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Sep 03, 2008 | La Crosse XG-55 Wrist Watch
Owner manual
Go up a level, then select your model.
http://www.gsi-usa.com/instructions/
I found my Coleman 40-842 there.
Sep 15, 2007 | Watches
Watches Logo
410 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
