check the hoses and clamps under the washer and the tub also as it may have a hole or crack in it? also check the water inlet valve as it may be leaking from the connecters
The normal cause of leaking while it is filling is a leaking Inlet hose. Try pulling the washing machine away from the wall and watch the hoses as the machine fills. If it is leaking you can see which hose is leaking.
You may either need new tighner clips or to replace the hoses depending on how bad they are leaking.
Another possibility is the water pump inside the washing machine could be broken and spewing out water.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Depends on where it's coming from. One thing you can check are the water inlet hoses. If they're not on tight enough, or the threads are crossed and there isn't a seal, water can run down the back, and through any openings on the back panel onto the floor. Another possibility is there's a leak from the drain pump, or the hose connecting the tub to the drain pump. Your best bet is: CONTACT THE MANUFACTURER!! It is brand-new and under warranty.
water can leak from the other valve while filling up if you dont have the hose on it,if you blank the valve off with a nut and tail with a coin and rubber washer in it that will fix your problem.hope this helps.
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer
overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage.
to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
