I am trying to find out how i can add an old turn table to a newer digital receiver. i understand the output of the turntable is analog and not compatible with digital inputs. the turn table is a Technics SL-Q200 and the receiver i am thinking of using is a Denon AVR-982
You'll will need a peamp device to boost the audio level of the record changer. preamps are still available try radio shack, they use to have one for about 40dls, but connect the turntable to an available input, something you are not using(aux) run a test with a record, you should be able to listen to the record but with a very low audio level, if you don;t then forget about the preamp and you'll need a a/d conversion device.
Testimonial: "further searching took me to the same info. you are correct. Radioshack actually has several phono preamps available from about $20 up. thanks."
--- Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast. --
http://4.bp.blogspot.com/_TaoBB_L8lt0/TDi__0VSpoI/AAAAAAAAACc/uS9ODAazZi0/s1600/HPIM0718.JPG
If you wanted to Equalize a single external analog source you would have to connect the EQ Line output to either of the two analog inputs ("DVD" or "Video" in your case) and connect your external source to the Playback jacks on the EQ.
The following is some boilerplate I made up that should explain some usage limitations.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
