fan oven element video.1, If the fan motor . in the
back of the oven is going round and the temperature light is on (normally
little red light), but there is no heat then you will probably need a new oven
element, these are generally very easy to fit and readily available from our
website these can be tested with a electric meter. To gain access to the element .you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element,. if you
look closely at the element .you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your fan oven is getting warm but takes a very
long time to cook or is burning the food more on one side than the other, then
you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your oven thermostat 4, A quite common and easily overlooked answer is if your oven
is not working at all ie: no heat and no fan then the chances are that someone
has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again. For all Free appliance repair videos visit our VIDEO
TUTORIALS
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
