Question about Netopia Cayman 3341 Router
Setting up wireless labtop with Brother MFC-5440N
I lost my Brother MFC-5440 CN set up CD and need to set up a Compaq Presario 2100 labtop using a Belkin network card. I have a NETGEAR wireless router that already has a IBM Captiva running windos 98 connected to the printer.
How do I get the labtop set up and print wirerlessly?
thanks,
bmcintyre@facilitysource.net
SOURCE:
  • 15 Answers
SOURCE: netopia router and belkin card compatability
Those two are indeed compatible. Are you sure the drivers (if any) were installed properly?
Posted on Aug 26, 2008
mitpatterson
  • 74 Answers
SOURCE: replacement paper tray for Brother MFC 5440 cn?
If you go to brothers website you should be able to order a new one from them for about $10 USD plus S+H or so
Posted on Oct 19, 2008
compucure
  • 61 Answers
SOURCE: Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Posted on Feb 25, 2009
  • 33 Answers
SOURCE: setup with a netgear print server
Be sure you have it setup correctly and the IP address is correct. Also you may want to check with Netgear on whether or not that model is compatible with Bi-Directional printers.
Posted on Jan 13, 2010
  • 93 Answers
SOURCE: my network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
Posted on Mar 09, 2010
Brother MFC 5440 CN, Can the color be turned off?
You may be able to select black only from the driver properties
One of the options is to use grey scale
goto printers right click on the printer Properties you may find the option within those settings
NOTE however, each time you switch the printer on it may use the colour as it starts and calibrates
Heres a link to the user manual http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=mfc5440cn_all&dlid=&flang=English&type2=-1
direct link to the manuals For basic information about the product. http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UkEngSoft_D.pdf Software User's Guidehttp://welcome.solutions.brother.com/BSC/public/files/dlf/doc000075/BH3FB_UkEngUsr_B.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Brother MFC-5440 Printer
Trying to restore back to factory what can i
When you purchased the computer, you should have received a set of "System Restore" CD-ROMs. Use them.
If you have lost them, telephone HP/COMPAQ, and order a replacement set of "System Restore" CD-ROMs. The cost could be $20 for the set, and $20 for courier-shipping. When the disks arrive, use them.
P.S. Backup all your music/files/bookmarks/contacts before doing the "factory" reset.
Nov 13, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq Service Utilities floppy Presario 2100
Access: http://www.compaq.com/support
and search for 'Presario 2100', then click on 'Device Drivers'.
Nov 07, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 5440CN Low Ink problem
Maybe you can try reinstalling the driver or if the cartridge was bought from 3rd party, you might want to buy one directly from the manufacturer.
Good Luck.
Feb 02, 2009 | Brother MFC-5440 Printer
Replacement paper tray for Brother MFC 5440 cn?
Jul 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Lost restore disk
> April 29, 2008.
Buy a new computer, with Windows 8, to replace your old 'XP' system.
Apr 29, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
No USB Port on printer
It is inside the printer, near the ink cartridges.
Apr 19, 2008 | Brother MFC-5440CN All-In-One InkJet...
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Netopia Cayman 3341 Router Logo
117 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
