Question about Coleman 10' X 10' Sundome Tent 9160K101
My fireplace does not light up in back.(yellow leds)Heater works fine.Model FL28-R.The red (leds) are working .I tested the dimmer control and it is working fine.Also I changed changed wires from red lights to yellow lights and the came on, so yellow (leds) are fine something on circuit board must be gone.I would greatly appreciate some help. THANKS
    Top Expert:
  • Coleman Master
  • 64,234 Answers
Sorry but we (fixya) can not help you FIX this contact the MFG or a retailer that sells them
Posted on Apr 07, 2018
2 Suggested Answers
SOURCE:
SOURCE: my heater on my coleman electric fireplace Model
HI,
Sorry for my english, I,m french. I'm from Québec, Canada.
I have the same problem with my fireplace. Same model.
Do you have the manual or the papers who came with the fireplace. My electrician need it. May you scan or fax to me?
Thank you very much.
Jacques Blanchet
Fax: 1-819-762-0130
email: jacques.blanchet@cableamos.com
Posted on Nov 30, 2010
Tip
How Does a Home Automation System Work?
Methods of Control
  • Components of a home automation system are controlled via various methods, depending on the manufacturer. Systems may be controlled wirelessly or may be hardwired. Wireless methods use radio frequencies like Bluetooth and infrared, while hardwired systems may use ethernet, phone cable, electrical wire or coax cable. Most systems use a mix of wired and wireless components.
Lighting
  • Lighting is handled by inline dimmers, lamp plug-ins and gas fireplace dimmers. Hardwired dimmers and lamp plug-ins are installed between the light and the power source. The dimmers regulate the amount of power sent to the light giving you the ability to adjust the brightness of the lighting. Fire place dimmers work the same way, they allow you to regulate the amount of gas released and control the brightness and mood your fireplace gives off.
Heating and Cooling
  • Replacing your current thermostat with a "smart" thermostat allows you to remotely program when your air conditioning or heating unit operates and what temperatures they maintain. led displaystransparent led screenThermostats can either be programmed to switch on or off at certain times or may be controlled through the internet via an ethernet connection. You can also control it wirelessly via RF signals.
Security
  • Security setups contain a base unit and any number of wireless and hardwired sensors for doors and windows. Sensors are made of two pieces that touch when the door or window is closed. But when the device is separated, by a door or window being opened, the electronic circuit is broken. The sensor reports the breach back to the base unit via radio frequencies. If the base unit is active when the breach occurs, it will sound an alarm and a phone line connection to dial pre-programmed contacts--such as emergency services or your cell phone.
Cameras, Surveillance and Driveway Reporters
  • If you have a driveway reporter, when something passes by and breaks its laser beam, alarm security systemthe length of the break and time of occurrence are reported back to a base unit inside your home via RF signals. Units detect the presence of people and vehicles but ignore animals. Cameras work similarly--they report video data back to a base unit via RF signals. Cameras may also use infrared technology for night vision or compacted circuitry for a smaller size. The base unit for the cameras sends video signals to a monitor, VCR or a hard drive.
on Mar 29, 2016 | Home Security
How do I get the fan to operate on my electric fireplace model FL28-R?
Is the same thermostat activating the fan? You may need to change it.
Sep 25, 2015 | Heating & Cooling
Purchased a Great World Ltd electric fireplace at BigLots. Model is either SWEO71 or SWE071. The flame and dimmer features are not working. Just put it together and mounted on wall, turned on, and
don't know this model, but does it have a light bulb inside? if so change it. they are often red or orange, but any will do to test it
Sep 13, 2014 | Heating & Cooling
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
I'm installing a vanity light in the bathroom. The old one had a dimmer attached. For the new fixture, attached two white from the wall to the white in the fixture. attached two white from the wall to...
Get a test light, a bulb in a socket with a black and a white wire. disconnect both the black and the red. Also have access to the white or the ground. Then with the power hold the white test light wire to the white of the house and the black to the black. .turn the dimmer on and off and see if it controls the light. NEXT do the same with the red, that is test light black held to red and test light white held to house white. once again check the dimmer.
Typically when you have a hot red and a hot black in a fixture the black is on the dimmer and the red is always on because it is connected to an outlet built into the light. OR the light can be controlled from two locations, one regular switch and one dimmer switch.
Mar 01, 2010 | Electrical Supplies
Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Dec 13, 2009 | Kitchen Appliances - Others
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Coleman 10' X 10' Sundome Tent 9160K101 Logo
128 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
john h
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
