I have a problem in asa5510 eth0 ip is 192.168.100.51 (inside) eth3 is static ip i can ping 4.2.2.4 from asa but i cant ping 4.2.2.4 from inside please solve this problems
Does the DSL router have a model number? Also for the public address, can you give me the first couple of digits. I just want to make sure it is truly a public IP address and not a class A or B private address because only an ISP can hand out public addresses.
If the IP address on eth0 is indeed private, I am guessing you have to get into the DSL router and set a static route to point to let it know about both of the the ar410 networks on each interface. Keep in mind it might not understand VLSM so when you static route in the DSL to the 192 network you will only need to specify it as 192.168.18.0 as class C default mask is 24.
type in these commands
I assume you are using a Debian flavor
sudo nano /etc/network/interfaces
auto eth0
iface eth0 inet dhcp (this is for DHCP, skip to CTRL commands below if DHCP)
iface eth0 inet static (this is for a static IP)
address x.x.x.x
netmask x.x.x.x
gateway x.x.x.x
CTRL-O
CTRL-X
sudo nano /etc/resolv.conf
nameserver x.x.x.x (DNS here)
nameserver x.x.x.x
CTRL-O
CTRL-X
sudo /etc/init.d/networking restart
Hello , the Steps which u want to export and import configuration in Cisco ASA5510 1- connect yourself to your Cisco gateway by IP 2- Get TFTP server to your PC like( solarwind , Tftp server , ... ) any tftp download and upload program 3- now u need to copy running configuration to your pc by order #copy run tftp , then follow the steps NOTE: u should be in the same network or u need your pc and cisco box both have publick IP
4- if u want to put prepair config files to your gateway , you will need to type order #copy tftp run , then foloow the steps
If u need anything else please let us know by leave your completely request or join us with www.fixya.com
Could you please post the config?
