Assuming your dell is the same as this one reviewed by PC magazine in 2001 it needs an IDE (a.k.a. "PATA") drive. It's old enough it may not recognize larger drives. You may have have to track down a 40 or possibly 80 gig IDE drive some where (eBay maybe?). In my experience people don't want them so you can probably get them rather cheap.
You would need to unscrew the thumbscrew located on the right side of the rear panel, press top and bottom cover release tabs and pull the cover toward you. To replace, perform the steps in reverse.
opening the case u have to see that the power supply is facing you when you lay it down.....check some PC case does not have screws, but levers that helps to remove cover...but if their is a screw associated remove them all then slide case back towards you and lift.
Check BIOS settings for any "boot sector protection" or similar. If this kind of protection is enabled, Setup will not be able to write needed startup files to the disk
Hi satti73,
I need you to explain your problem a little more clearly.
I think you are saying that when you press the ON/OFF you get a display? What is the display that you get? How old is this machine? What other events have taken place leading up to this problem. Do you get and error messages on the monitor? DO you get any sort of sound emitting from the server when you press the ON/OFF butoon?
