By Wii Fit Plus, I presume you mean the Balance Board. If you take the battery cover off the balance board, you will see a small red button. On the front of the Wii unit itself, there is also a small red button. Press them both within a short amount of time to sync them together. From this point forward, they should be able to talk to each other.
You need to put in the Wii fit game and bypass all the screens until it is looking for play options.Take the battery cover off of the Wii board and open the large cover on the front of the Wii console.Press the sync button inside the battery compartment on the board,then press the red sync button at the top of the open console.If the blue light stays on constant,they are synched.If not,try again.Good luck and Game On!
if by doesnt begin you do you mean doesnt read disc or fails to start game because if its doesnt read disc look for scratches on the disc if its doesnt initialize then it could be the disc drive itself is bad then go to http://www.nintendo.com/consumer/systems/wii/en_na/index.jsp
Have you sinced (Sp?) it yet? If not, here is how you do it. On the front of the Wii, there is something you can open up. Inside of it, there is a red button. On the inside of your battery cover for your Wii fit, there is also a red button. Start the Wii Fit game, and it will ask you to sinc the board, when that happens, press the button on your Wii Fit, and then, after 2 secs, press the button on your wii. (Do NOT hold down the button on your Wii.)
dont have a wii fit but, try to reconnect the remotes by pressing the button with the blue house on it on the wii remote, and pull up the wii remote settings. then, press the reconnect button on the remote and follow the directions. if that doesnt work, open the battery compartment on the remote and when the wii is on, press the red button inside the battery compartment on the wii remote that says SYNC. if that doesnt work, try the SYNC. button inside the wii itself. (located in the door in the FRONT of the wii. it has a spot for an SD (scandisk) memory card) it is a rectangular bigger button than the wiii remote. even if none of these options work THANKS FOR READING
