My flash drive does not work. No flash drive icon shows on MY Computer
The most likely solution to this problem is to go to the computer manufacturers website and find the drivers for your flash drive and install them.
After this, your flash drive should work fine.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Connect your flash drive to your computer using an available USB port.
If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive.
A question mark icon should be shown to the left of the label.
Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes."
This will scan your PC for any new devices.
Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive.
If this process was successful, your flash drive should now show up under My Computer as a storage disk.
If its listed as an unknown device
Then right click on your flash drive select rename
Hope this helps
have you formatted it? and try to go to disk management, and look if it stands there. if it is there, you can always fix it. if it isnt in there, you might have a hardware problem =/ which flash drive + computer are you using? elamre
