It might be that the sound amplifer is defective if you know anything about electronic you can fix it . If not better take it to someone who can repair it.
The amplifer is the part of electronic that amplifies current so the speekers can be driven. Check it if there is a bad solder or anyhing suspicious.
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
SOURCE: Philips tv sound doesn't work
It could be the audio circuit faulty, either the IC or other parts - pls send to a service center.
SOURCE: My 36" Flat-screen CRT Philips TV turns itself off
I'm getting the exact same thing with a 26" model. First I found AV2 started carrying AV1's input so we put a switch in. Then it starts to shut off with the twice blinking light after viewing the scart input for a while. I'm currently trying feeding it scart set to composite rather than RGB to see if it'll stay on. One other thing - I just got a oneforall remote. I don't suppose you did - in case that is triggering something?
People are reporting a fault with the "painter" chip which is terminal usually. But that seems to manifest as the tv switching to scart input spontaneously. I haven't seen that.
Hope you get somewhere - I'll let you know if I find anything.
SOURCE: Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
SOURCE: Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
