It certainly sounds like something is wrong. My first GE microwave was like this and it wasn't advertised as anything special. After a long life I replaced it with a Sharp (makes most all microwaves) and was disappointed at the cycling on and off. Now Panasonic makes what they call Inverter microwaves with continuous power. I recently bought a GE (probably made by Panasonic) with this Inverter technology and am very pleased with it. Make sure the microwave you have says AccuWave on it, if it does, it sounds like the magnetron may have been replaced with a non-continuous type of magnetron. Was it bought refurbished/returned/clearanced? I think when I was researching this that it MAY have something to do with the type of power supply to the magnetron and not so much the magnetron itself.
I don't know about the fuse on the stove but check and see if its still plugged in and make sure that the wiring is sound and then go to the breaker box and see if the breaker is tripped. And Most electric appliances have a safety fuse somewhere.
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected]?
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
There is a high voltage fuse in the unit attatched to the high voltage capacitor, it is the most common problem for microwaves not working. Also check the protective diode,the high voltage capacitor as well as the transformer if the fuse is ok. Good Luck.
