KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
Anonymous Posted on Jan 12, 2010
Kitchen aid mixer drops metal shavings in the
575 watt Professional 600 Kitchen aid mixer drops metal shavings in the mixture on any speed above 1.
  • Anonymous Jan 12, 2010
    Hi halincoln,
    Thanks for the excellent advice, recommendations, procedures, and links. All helpful. I did successfully disassemble the gearing and planetary unit and found the problem (and a lot more metal shavings): the top of agitator shaft just above the pinion gear (32) is grinding into the aluminum housing of the lower gearcase itself. It has cut a channel about 1/16 to 1/8 inch deep already. The depth is not consistent all around the circumference of the newly cut channel. (By the way, there has always been about an 1/8th inch of vertical travel in the agitator shaft since new.)
    Also, the assembly of my agitator shaft is different than shown in the parts manual. The manual shows a washer (31) between the the snap ring (30) and the pinion gear (32). Mine has none. Moreover, the parts manual does not show a washer between retaining clip (7) and the bottom of the planetary unit's connecting tube. Mine has one. Was my agitator shaft misassembled?
    So here is my hypothesis and my next questions. I think that the (increasingly) heavy viscosity of making bread dough is acting to force the agitator shaft into the bottom of the lower gearcase. That created the channel and shavings. Using the machine on low viscosity fluids (like cream) but high speeds (to whip it), produced shavings in the food by centrifugal force throwing out already cut (but trapped) metal. Here are my questions. Should I
    1. assemble the agitator shaft as shown in the parts manual, or
    2. add another washer above the washer I already have above the retaining clip (7). My idea is to fill that space and not allow so much vertical play in the shaft but still allow shaft to turn freely.
    Again, thanks for your help and let me know what you think when you can.
    Redlacquer
Anonymous
Level 2:
  • Expert 235 Answers
  • Posted on Jan 12, 2010
Anonymous
Expert
Level 2:
Answers
235
Questions
0
Helped
179586
Points
831
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
  • davek22 Mar 12, 2011
    I have the same problem with a 1 year old KA Professional HD stand mixer. After disassembling the planetary assembly, I found a mass of aluminum shavings in it. I finally figured out that the spiral dough hook pushes up on the attachment shaft so hard when kneading dough that it dislodges the bottom snap ring on the shaft and pushes the planetary spur gear up into the aluminum housing. I replaced the snap ring but it still dislodges it. The hook-shaped dough hook does not push up and dislodge the snap ring, but it is less effective at kneading. I guess that KA is not made for real bread making.
I have a KitchenAid Professional 600 6 Qt, 575 W mixer, not a tilt head model that has a bad head wobble and looking how to fix it.
Yes and isn't that the dumbest design for something like that. 3 screws when older models had 4 and no locating pegs where older models had 2. Great progress Kitchen Aid.
1helpful
Kitchen aid mixer kg25hoxer repair manual
Manuals Literature
Kitchen Aid manuals link above
Sears link to manual below (may want to simply search with Google.com using the model name and number for parts if you plan to repair it yourself.)
KP26M1XSL5 KITCHENAID 6 QT STAND MIXER PROFESSIONAL 600 BOWL LIFT Manual...
Feb 26, 2018 • Food Mixers
How do I fix a kitchen aid mixer that possibly shorted out?
Buy a new one quick. Or hide. Spent . electrical engineering. And supply of new diodes resistors and capacitors are needed.
Motor clicks every turn
The clicking is probably a small nick in one of the gears, even the smallest chip can cause alot of noise or make the mixer click. Is the beater shaft still turning when you have a load in the mixer (bowl is full)
Or is it just clicking?
If the beater stops turning it is going to be caused by stripped gears, however if it is just clicking this would indicate just a nick in the gear. Either way I would recommend opening the mixer and replacing the damaged gear/gears.
Your mixer is considered a 5 Quart Professional, which means it has the same parts as a KitchenAid 6 quart mixer. The first thing you will want to do is take the mixer apart and disassemble the gearing. You will want to clean off the gears with paper towels and wd-40. Carefully inspect each gear once clean and replace damaged gears.
In the professional mixers when a gear strips you need to replace the grease and housing gasket, this is because the gears are all metal and there may be metal shavings in the grease which could cause the gears to strip again.
The most common gear to go bad in the Professional series mixers is the Worm Follower Gear (9706529). Here is a link to that gear on our website: http://www.mendingshed.com/wormfollower.html
Also, here is a link to the service manual for the mixer, this will aid you in taking the mixer apart and putting it back together correctly. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
We are one of KitchenAid's largest service centers within the US, and all parts we sell are genuine KitchenAid products. All parts are available at our website, www.mendingshed.com
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Kitchen aid professional stops spinning
the pro series 600 has a worm gear, a worm follower gear, a bevel gear, and tree bearings the front rear and thrust bearings any of the above will cause the mixer to halt, to operate noisily, or grind, you need to open it up and look under the transmission cover. If it is an older model it could also be the transmission cover if it is a plastic one, My first thoughts is it is the worm follower gear. hope this helps you in the right direction.
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
2answers
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
