Sunbeam heating pad no longer heats. The red light on high temperature just blinks and I can't click any other temperature. It's not that old. The heating pad model is CAT93, Controller model SW114. Thanks for any help you can give me.
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Thank you for this fix it worked like a charm, so easy yet so clever, Thanks again
Wow!!I was going to throw away mine and I just click your comments it work ..yaiks ..!! Thank you!!!
Thank you VERY much. I had the same problem and had the controller apart and was checking components until I found your answer. It is working now even though it still emits a strong electronic/chemical odor (It did this from the time it was new). Every time there is a very short power interruption the controller goes into the flashing mode, Usually, I could unplug it and plug it back in to get it working again. This time it only returned to normal when I pressed and held the power button as I plugged it back in.
Throw away and purchase new one
I have a CAT93 heating pad with a SW104 controller that does the same thing. Have not found a solution yet, besides throwing it away and purchasing a new one as has been suggested.
