If it's clean water the fill valve is bad turn water supplies off see if leak stops. Is it still leaked with water supply turned off check drain hose could be to low causing drain water to back fill into tub
Hello! The drain plug is located near the front passenger side wheel well...Open it up and drain the
radiator... What I like to do next is remove the t-stat and replace
waterneck... Now fill radiator with water (actually fill degas bottle) and
run engine with upper hose removed at radiator... Flush until only clean
clear water comes out of hose... Drain radiator, replace t-stat, fill
radiator with coolant and you're done...Guru....Saailer
does the water keep running and it keeps draining the water? if so your drain hose needs to be higher than the highest water level in the tub or it will drain as it fills.
It sounds like the drain hose may be below the tub level. This will syphon the water out before it ever fills up enough to turn off. The drain hose should go into the plumbing drain at a height above the top level of the tub. Hope this helps!
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe. Also make sure the drain hose is not going too far down into the drain pipe. You may be getting a siphon effect.
Well...if the water is running, the tub is not filling, and you don't have water all over the floor, your drain hose is installed too deep in the drain pipe, or just installed too low, so that the water is simply running out of the machine and out the drain hose.
