Coleman 10' X 10' Sundome Tent 9160K101 Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Centre pole is failing to hold tent up in any real wind
Hi Guys, I have a tent pole which goes through the centre of my tent. A tough outback tent from Australia. Imagine if you will a t-**** shaped tent. The centre pole needs to be strong and when pushed up through the centre holds up the tent. The existing pole is telescopic. A pole fits inside the other and when the pole is lengthen to raise the tent to required height you have to turn the screw at the side of the pole TIGHT to prevent the pole from closing together the two pieces. PROBLEM is that in a good wind the pole does work itself free and start closing dropping the tent. How can I fix the problem so this doesn't happen? Steve
Anonymous
Level 2:
New Friend:
  • Expert 160 Answers
  • Posted on Jan 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
160
Questions
0
Helped
64998
Points
350
TRY DRILLING A SMALL HOLE ON THE INNER POLE SLIGHTLY SMALLER THAN THE DIAMETER OF THE SCREW. U WILL WANT TO DRILL SMALL HOELS EVERY FEW INCHES(CM) SO THAT U WILL BE ABLE TO SET THE POLE AT VARIOUS HEIGHTS IN THE FUTURE.
Pitching instructions for a great outdoors executive 320 tent and sunroom
This is a duplicate of a previously asked question on FIXYA from 2012, where an exact set of instructions could not be found, but two proposed answers were given.
For a similar but not the same tent, the scanned document still exists online:
https://drive.google.com/file/d/0B1SdA-vKLONwZ05vTGZKdF9BTzQ/view
https://www.fixya.com/support/t7407226-need_pitching_instructions
Quoting from FIXYA question from 2012
Wollocks
Jim,
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
Two rooms plus a fully enclosable veranda.
(4.9m long x 4.3m wide x 2.4m high)
Main Tent Assembly :
Lay the tent out on the ground (making allowance for the slope of the ground, prevailing wind, general access, etc).
Peg down the main corners and centres of each wall, keeping the tent square and evenly tensioned. Peg down remaining loops.
Assemble two sets of side support poles. These have been numbered (from the front, looking towards the tent (ie, facing the veranda)) :
Left-hand side : L1, L2, L3, L4 & L5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets of poles 5 & 9).
Right-hand side : R1, R2, R3, R4 & R5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets of poles 5 & 9).
Place poles in the loops along the sides ensuring that the 4 brown loops (at each end of the sides) are looped behind the projecting studs (this ensures the sides don't slide into the centres.
Lift & tension one side, then the other.
Assemble the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7 (corresponding to poles 12, 13, 8A, 24, 3, 4 & 8)).
Slide the centre poles through the centre of the tent. Use poles 14A & 15 to hold up the rear of the tent, poles 14A & A in the centre, & two further sets of 14A & 15, one set at the front of the tent & one set for the veranda. Tension by expanding the poles.
Assemble poles A, BE, C2, BE & A through the centre of the tent, clip onto ridge poles & tension. (Note : poles A should be inserted from the outside, through the elasticised holes before being inserted into poles BE).
Attach a guy rope to the rear of the tent (top of centre pole 15) & tension.
Veranda Assembly :
Assemble 4 sets of poles (10 & 30) & place in corners & centres of the veranda. Attach guy ropes & tension. Attach veranda walls (using Velcro strips).
Porch Assembly :
Select which side is to be an entrance. Unzip the window covering & use two poles (10 & 30) to lift it. Tension with 2 guy ropes on each pole.
hope the above helps.
Warwick Annear
[email protected]
Need instructions on assembling 2-5 person house shaped tent
House shaped tent is not an adequate description to make erektion suggestions.
Broadly speaking tents are divided into categories of dome, tunnel, ridge, bell or frame.
The ridge tent is sort of house shaped and the classic frame tent also, though this is usually referred to as a bungalow or perhaps chalet tent. None of these types peaks in the centre of the top and neither does a house, usually.
A small marquee peaks in the centre of the top and is also vaguely house-shaped but it seems somehow unlikely you have a small marquee..
It is also important to know whether there is an inner and an outer tent or flysheet and a sewn-in groundsheet, single pole, ridge pole, frame, fibreglass rods or perhaps an A frame.
I can't advise much without knowing what sort of tent you have but I advise you to practice, practice, practice and colour code or number each pole assembly. Bad weather when pitching for the first time is too late to be trying to read instructions and wondering which pole section goes where.
I also advise taking extra pegs and guy ropes in case of accidents or really foul weather. Tents are provided with minimum equipment for moderate weather pitched on hard packed loam type ground.
For different types of ground; sandy soil or rocky different designs of pegs are available and should be used along with heavy stones or sandbags. Double pegging is also advisable in some circumstances.
Preparation and attention to detail is the key to a successful camping trip. No extra precautions often turns a simple camping trip into pure misery. I once camped at the top of a high cliff when bad weather was expected. I double-pegged and fitted extra guy ropes and slept right through a gale while my companion laid awake petrified. The tent never moved but in the morning we were the only campers left on that part of the site.
How do i put up my tent
Hi Anonymous:
Lets look at this as a fun project. Lot's of us ALWAYS throw the instructions away first just so there's more of a challenge. Anybody can follow instructions but without them, you have to use logic. It's FUN TIME!
- First, separate all of the parts into separate pieces, by description, size, colour, any hint you can get.
- Next, spread the tent out, right side up, so that you can see its general shape.
- Mentally pretend that it is inflated full of air so you can visualize what it's supposed to look like assembled.
- Lots of tents are held to the ground with Tent Pegs. If there are loops around the perimeter of the base, there should be pins (wire or plastic) that will go through these and into the ground.
Support - something has to hold the tent up. It could be a post in the centre, flexible hoops, pieces of pipe.... It's up to you to sort out the pieces, arrange then so that when they are attached to each other they can go through loops in the tent fabric and ultimately hold it up.
- This is the time when you either say "Hey, I can do this" or "I need more help, this is what the tent looks like". Either way, We'd like to hear how it goes.
Remember, It's FUN!
I have a magellan yukon (23-010) 20'x9' that has some broken poles. Where can I replace the poles
You can replace tent poles. I've never used them, but you can try http://tentpoletechnologies.com/. Otherwise I would suggest buying replacement poles from Academy (who makes the Magellan Outdoor line) or trying to find generic poles and an sporting goods store. Best of Luck!
6helpful
2answers
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
2answers
I got the tent but no instrutions with it.
first lay it out on the ground put the pegs in 4 corners & centre then place the ropes and peg them into the ground about 3ft from tent then place the poles through the eyes of the tent erect the poles centre ones first stand the poles up then it should be upright from there just continue to add poles and ropes adjusting it during this procedure
hope this helps
1helpful
No instructions on how to set up 3-bedroom Coleman tent.
First, I would try Coleman.com and see if they can send you a manual or direct you on their website.
Assuming the picture is the tent I can help (and even if it isn't, these are basic setup steps). Peg the tent down. Lay it out and pick about six spots to peg it down.
Next, get the two or three longest poles. These are the support poles. Run them diagonally or maybe side to side through the pole sleeves on the top of the tent. Once all the way through, put one end in the hole (or possibly in the pin) depending on if you poles have points or holes in the end. You'll then bend the pole, raising a portion of the tent to make the other end of the pole fit. Look for hooks to hold the tent poles to the poles. Do the same for the other pole/s. And it doesn't matter which pole goes together first.
Once you have the two or three longest ones in, the rest is extra. From the looks of it, you may have one pole running from the door area to the rear. If there is one, it's usually slid into a pouch and tied with a plastic string at the top of the tent to the other poles.
Other poles, if they are there are for side support or rain cover support.
Figure out which way the rain cover goes, then attach the bungie to the pole at the base of the pole. It should have some type of hook. Once the cover is on, it may take a pole underneath it. If so, there will be a small pocket or pouch for the pole.
Don't worry about the strings and extra stuff. (Unless you're expecting monster winds). You should have extra pegs, strings and maybe a pole or two. As long as you get the main two or three support poles up, you're solid. Good luck
Instruction to put up a Coleman Rock Springs 4 Tent please?
Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
Lay it down, stretch it out and peg it. That will save you a ton of time.
Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
Good luck
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
