I have a Dell Precision 340 Minitower desktop. All was working and the hard drive gave me problems. I chenged the cable and then I am not sure what I did and now the power switch does not work. Power Green LED on the motherboard turns on, the Power supply fan revs up when I place the Power cord in, but the switch does not start the machine up. I changed the HD cable again. I have removed everything except the motherboard and power supply, but still the switch does not power up the machine. I have doen it with case opena nd with case closed.
Can I bypass the power switch and turn on the mmachine merely by inserting the power cord? Any jumpoers would allow me to do that?
Many thanks and regards
Change everything
The panel cable for power led has not been pluged to the right jumper pin.
firstly you pluged the panel cable for the power led to the wrong jumper pins.
secondly, find the right junper pin for power led and plug, find the panel cable for the power led, plug the panel cable for the power led to the right jumper pins.
i mean unplug the panel cable for the power led from where pluged, search for the right pins and plug to them then the power switch will control the power on and off.
from UZOWUANYA.
e-mail [email protected]
Fauza
Hi
First things first:
1) You just change the power on button for other, on Radio Shack they have it.
2) cables that came from the motherboard to the ON/OFF SW. you have to soldering with the new Power Button, thats it. very easy task! you can use any power botton to fix this.
good luck
