SOURCE: Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
SOURCE: patton air circulator motor cuts on and off, used
I would recommend that you replace your fan. It sound like you got good use out of it. A good fan for you may be the Lasko 3900. Not only will it circulate the air but it will filter it also and the filter is easily replaceable. Here is a link to Amazon where you can check it out.
http://www.amazon.com/Lasko-3900-Performance-Air-Cleaner/dp/B000MF8VLS
I hope this helps you.
