Hey,
Can you help me. I have a HP 9110 machine. When i send or recieve faxes the fax report prints out and gives error codes. These are Error 282, 388, 421, and 233. Can you tell me what these codes mean?
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop
button. (OR) Sometime Call waiting service might cause this error code.
Thank You
I am getting a fax code error of 406 all the time. Any idea what that means? Also, my 9110 seems to be hooked up properly, but it won't scan anything. Says there is no scanner hooked up.
Thanks
please be inform me when i send documentit is showing conecting and sending fax indication come faxed send failed.when i take report of send fax it showing error code 388 .
would you like to give me any soluation
Fax Report Result shows Error Codes 252 and 410
