Bulova Watch Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Glass that covers the face of the watch is shattered-$ to replace
The glass (or crystal as it may be called) on the face of my husband's Bulova watch is cracked and shatter. What is the average price to replace the glass??
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 11, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813855
Points
13579
I am not sure about prices in US, but over here in England we charge £15 - £25 for mineral glass (depending on size, thickness, e.t.c.) and £50 - £120 for sapphire glass. As for today: £1 = 1.60$. Doesn't matter how you name it - glass or crystal, both are right.
5helpful
4answers
I cannot get the back of my Bulova watch back on. I popped it off to replace the battery however I cannot get the back back on!
Most Bulova Watches have PRESSURE TIGHT backs. Meaning the back is applied with EQUAL amounts of pressure to the entire back. There are two(2) solutions:
1. Take the Bulova watch to an experienced watch dealer/repaiman, to have the back applied, or
2. CAREFULLY MAKE SURE THE BACK IS IN THE PROPER POSITION, then WRAP THE ENTIRE watch with a soft, cushy clothe and with a pair of pliers, CAREFULLY apply pressure to the center of the back plate, until the back covers seats to the proper depth(closed), at the same time BEING VERY CAREFUL not to crack the watch crystal!!
Dropped my watch on kitchen floor, glass face is now in four pieces! where can i get it replaced?
Any decent jewelry store can replace the crystal unless it is a very unique watch in which case they may have to order the crystal.
Dec 24, 2010 • Watches
8helpful
3answers
Can't get the back of my watch back on
mcdevito75 here, Your Timex watch back cover should have a cutout in the back cover for the stem (winder) make sure this cutout is lined up with the stem the stem lies in this cutout, once you have it lined up, lay the watch down, crystal (glass up on a sturdy surface, Table, counter top etc. Now, with your palm and even, even pressure on the crystal (glass) simply press down, you"ll hare it click shut. Don"t force anything and if you still can"t get your watch back cover on, look for a small watch repair shop in your arear. It may take a special pair of pliers to get the cover on. Most Timex back covers are kind of hard to get back on.
The glass face has cracked how much will it cost to replace it
mcdevito75 here, Cartier a FINE watch, replace the glass crystal, I would figure approx. $100.00 maybe a bit more. Look for a small watch repair shop in your area to save on cost, and they most likely will have to order the crystal straight from Cartier.
HOW MUCH WOULD A REPLACEMENT GLASS FACE BE
mcdevitohere, Expect on average to spend $25.00------$40.00 at the jeweler for a new crystal (glass) also, look for a small watch repair shop to save on the cost.
I have scuffed my glass face on my hugo boss maxx watch
A watchmaker or some jewelry stores can order it for you if they don't have a suitable replacement in stock. Depending on the severity of the damage they may be able to buff out the existing crystal to almost new condition. As long as it's not cracked it can usually be buffed out for just a few dollars.
1helpful
Watch face glass cover scratched where do i get a new one from. La coste law6200L
You can get from any experience watch maker work shop who do customized crystal or send your watch to La Coste Service center and if you are in chicago illinois
we do customized crystal at
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Sep 14, 2009 • Watches
4helpful
I can't get the cover to close on a timex watch.
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
The crystal on my Skagen titanium developed a pressure crack which, in less than a day, spread to almost a complete circle. Crystal obviously must be replaced. Who does this work and how much does...
Contact the manufacture to find out who their authorized service rep is for your area.
I had the glass or crystal break on some of my watches. The glass or any outside parts are not normaly covered by warranty.
Jerry G.
72helpful
15answers
HELP !! can't snap armitron watch cover back on
Take a small thin piece of cloth or paper towel, fold it and use to cover the watch face.  Put one quarter (coin) on top and one quarter (coin) on the bottom.  Place the sandwich in a pair of pliers, center thhe pliers and press, when you hear the snap, the back is on.  Do not use on a watch with a domed crystal, or at least use a lot more padding over the face.  Takes 10 seconds.
Jan 20, 2008 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
