I too have the problem in which the sound only comes out of my left speakers.. I tried switching the inputs from red to white and visa vera and the only way it plays is with the white plug in either the red or white inputs in my stereo.. I also have a switch on the back that says line or phono and when i put it to line it does nothing.. phono just plays out of one side.. Is this my amp or my brand new record player?
If you put the good channel from the deck into the right and then left phono imputs of your amp, the sound should come out from the left and right speakers. If it only comes out from the left, then the amp as a right hand channel fault. Now if other devices work on both channels, then it's the pre-amp for the phono socket that has a fault on it. You should be able to find this by following the wires from the phono socket. If you touch around that pre-amp you should get it to buzz on either channel (where it joins with the main pre-amp). Doing this with a screwdriver will pin-point where the faulty part is (working backwards). PS don't short anything by touching to bits of metal together with the screwdriver.
Magnetic cartridges need a small pre-amp before they can be past to the main pre-amp. That's why you can't hear anything with the deck plugged into another line socket.
If you get signal on both left and right speakers with the above test the deck is to blame.
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
