I have a Casio AQ-47 watch. I removed the battery and now the alarm does not work. Where does the little spring get attached?
This little spring is called coil spring and must be inserted in to the hole in movement. Usually there should be writing on movement with an arrow pointing to that hole. If you can not find the writing, then try to put coil spring in different holes one after another, till you hear the watch beeping again.
Rate me, plz.
