Http://www.bealsmotor.com/
This web site has been a great help for all my Dayton heater parts. They have all the parts straight from the owners manual with prices. It shows the picture of all the parts just like the owners manual and how they all go together. Good Luck!
SOURCE: 100,000 btu therm controled heater
What did you set the air pump pressure at? This is critical on heaters with Hot Surface Technology. Setting the pump pressure is always the FIRST place to start troubleshooting on these heaters.
Here are some things that can prevent ignition even though there is fuel & glow:
SOURCE: need help with the wiring on the reddy heater 110
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
SOURCE: i need a ignitor for a 150000 btu construction
You can get them at www.allpartsinc.com
Here is a link:
http://www.allpartsinc.com/Items.aspx?key=search&code=__ALLCATS__&searchval=pp200&incl_m=F
