You should have the driver for this in Windows 7 by default if it works don't worry about it - if it doesn't work - look for it in driver and hardware - remove it and then reboot the pc. The pc will automatically find the printer sand seek out the Driver and install it.
Get back to me for more information and will follow up with you for the next few days if need be.
where can i find driver for my epson CX2900???i already downloaded the driver for for my epson but it is the wrong one and it is only for printing, i need a driver for scanner so that my scanner will work. . .thanks in advance for those who willing to help. . .
I do not see this scanner on the Epson support site. They may not have a Win7 driver. You could try an XP driver in the compatability mode (right click on the driver and select Properties and the Compatability tab. Check the box next to Run in compatability mode) You can download a driver from a site like this one, http://download.cnet.com/EPSON-GT-7000/3000-2118_4-73143.html .
Another possibility is available in Win7 Pro and Ultimate. Download and install the XP mode from Microsoft. Install the scanner in the virtual XP computer. You may need to save files to external media to transfer them between the two computers.
Download the epson twain driver from their website:
http://www.epson.co.uk/Scanners/Epson-GT-7000/Drivers-Support
When installing, select the driver inside the 2000 folder. It works in XP. You may have to install via the device manager.
Stephen
I got mine working on Windows 7 (x64) by doing the following:
1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site
2. Install the drivers
3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator
4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027
5. On line 51, 54, and 57 replace PID_011B with PID_0101
6. Save the file.
7. Connect and turn on the scanner.
8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software
9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked).
10. Say ok to the window that pops up and it should start installing the drivers.
In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
I hope that works for you :)
Stephen
Once it is installed on Windows XP you can change the setting in properties to run Windows 98 compatible. It used to work with older scanners and printers. Try it out.
i have scanner epson GT9000(ES 1200C) and lost the driver to runnig it , I did fomat to my pc now my scanner not function pleas if you can help me to povide me the scanner driver.
unfortunately Epson has not made a driver for this scanner that is compatible with Vista and from the looks of it, they don't seem to have any plans on making one! Sorry
