Hello there, The machine is attempting to do an incline calibration. Keep the unit lowered as you have it, reinstall the safety key, allow the unit to go all the way to the top and then all the way to the bottom. The machine will stop when at the bottom and the screen will go back to normal. The machine will not overtravel the incline motor and damage it. Just let the calibration finish the procedure and you will be fine.
Good Luck! Tim
FYI this will happen anytime the safety key is removed while the incline is moving on nordictrack brand machines.
Hello, I have a similar problem with my nordic track A2050 treadmill, it also has worked flawlessly until today, It was unfolded and I turned on the unit with the safety magnet and it just started inclining. The display showed only incline and a couple of dashes. I turned it off and then tried again, it just kept inclining so I turned it off again, unplugged it and plugged it back in at which time it started again without the magnet! It is now jacked up and I can't fold it or use it. Please help! Thanks.
