Hi sir ....... when the copier ( kyoceramita 5530 ) worming up the error code C3300 is shown ? plz how can i fix it.....?
Optical system (AGC) problem
1. insufficient exposure lamp
luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness
connections; adjust position of contact glass shading plate or
clean/replace the scanner home position sensor; replace the exposure
lamp or inverter pcb if needed; replace CCD unit or engine/main board
if applicable
Hello sir; Here are some problem; exposure lamp, CCD, shading plate position, engine board, inverter board. I would like you check the exposure lamp first, lift up the cover make a copy see the light is on ?
