There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: Kenmore Dehumidifier
if the compressor is running it sounds like a refrigerant problem or dead compressor in both cases its not cost efective to repair dan
SOURCE: Dehumidifier does not collect water.
I had the same problem. I just narrowed it down to the humidistat by wrapping it in a baby wipe. It runs smooth now and fills the bucket....I'm off now looking for a replacement.
SOURCE: Kenmore 54501
Normal
0
When you push the power button, the blower fan comes on. In
a few minutes you should hear a second "click"--that is your
compressor starting. Do you hear that second click?
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The
'coil' (a finned metal part that needs air to flow across its surface) may be filled
with dust and obstructions, so no air can move...then no water. There is a
blower motor that must move the air. If it is seized up and not blowing
air...very little or no water. The compressor creates condensation from
air moving across the coil (like the moisture than forms on an ice filled
glass on a humid day) to extract the water from the air. If it's not
working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not
working. If it's real hot air, and the humidifier keeps cycling on and
off quickly, the coil is dirty. Those are the 3 things that need to be
working.
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
There are many reasons why a dehumidifier will not work or collect water.
heatman101
