My Olympus VN-6200 PC suddenly stopped working. I didn't drop it, I didn't spill coffee on it, it just stopped working for no apparent reason. When I connected it to the PC, the computer did not recognize it. I guess I will have to take it to a data recovery place.....unless someone has any other ideas. Thanks.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to another PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Good Luck!
You can recover files from Olympus voice recorder, see this solution
How to recover deleted files data from Olympus digital voice recorder
good luck!
SOURCE: Olympus VN-3100PC Voice Recorder Problem
I fought with this machine for more than 9 months. And after playing with it today FINALLY got it working.
This is what I did:
Unscrew the faceplate. (Three screws. One is under the batteries).
Put the batteries back on.
Have the HOLD button on the normal position (down)
Press and hold the MENU/FOLDER button together with the STOP button
Press and hold the MENU/FOLDER button together with the DISPLAY button
You will see a GREEN light, then a RED light then a "FOR" message will appear
Press the DISPLAY button and after a few moments it will reset and ask you to enter the time.
GOOD LUCK. Let me know if it works for you.
HAVE A NICE DAY.
SOURCE: Unable to record
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
SOURCE: Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
